Homemade Clutch Center Nut Removal Tool
Chris Edwards on mad-ducati.com
Homemade clutch center nut removal tool intended to prevent a clutch drum from turning during removal operations. Tool was constructed by bolting steel clutch plates together and welding a handle to the uppermost plate.
Sep 06, 2013 2:58 AM
Altair
I had those moments where the solution is staring right back at you. Nice job of making a clutch tool out of clutch components.
- Hand drill chainsaw accessory - GIF by ToolTalkBot on 2024-10-16 19:13:02
- Brake--Sheet Metal--28 inch by remidgett on 2024-10-16 18:53:51
- Squid jigging trawler - GIF by Ralphxyz on 2024-10-16 18:42:01
- Flipping rail track switch - GIF by BuffaloJohn on 2024-10-16 16:06:29
- Leaf removing machine - GIF by BuffaloJohn on 2024-10-16 15:52:12
- Manufacturing grinding discs - GIF by ToolTalkBot on 2024-10-16 15:42:02
- CNC lathe spindle shaft - video by Jon on 2024-10-16 13:53:17
- Roller stand from scissor jack - video by Jon on 2024-10-16 13:46:20
- Piston ring end gap grinder - video by Jon on 2024-10-16 13:44:49
- Powder coating oven - video by Jon on 2024-10-16 13:44:20
DIY Clutch Center Nut Removal Tool - comment on how to build a Clutch Center Nut Removal Tool - 1 comments
Altair says:
