Homemade Floating Output High Voltage Power Supply
David Prutchi on diyphysics.com
Homemade floating output high voltage power supply constructed from a neon sign transformer, variac, diodes, Delrin, shellac, high voltage outputs, and a surplus panel meter.
- Flipping rail track switch - GIF by BuffaloJohn on 2024-10-16 16:06:29
- Leaf removing machine - GIF by BuffaloJohn on 2024-10-16 15:52:12
- Manufacturing grinding discs - GIF by ToolTalkBot on 2024-10-16 15:42:02
- CNC lathe spindle shaft - video by Jon on 2024-10-16 13:53:17
- Roller stand from scissor jack - video by Jon on 2024-10-16 13:46:20
- Piston ring end gap grinder - video by Jon on 2024-10-16 13:44:49
- Powder coating oven - video by Jon on 2024-10-16 13:44:20
- Engine leveler - video by Jon on 2024-10-16 13:43:32
- Pressure washer from chainsaw - video by Jon on 2024-10-16 13:43:15
- C-clamp - video by Jon on 2024-10-16 13:41:30
DIY Floating Output High Voltage Power Supply - comment on how to build a Floating Output High Voltage Power Supply - 0 comments
Be the first to comment on this DIY Floating Output High Voltage Power Supply, or add details on how to make a Floating Output High Voltage Power Supply! Click the "add comment" button above to comment.
