Homemade Fuel Pump Push Rod Fixture
duaneb55 on weldingweb.com
Homemade fuel pump push rod fixture constructed by welding a drill alignment tube to an OEM mounting plate. Intended for a GM 90-degree V-6 with a mechanical pump.
Jul 20, 2020 8:31 AM
jimpat
where are the directions? Just paid 5 bucks to look at a picture?
Oct 30, 2018 11:15 AM
warning
I need to make one of these also. I just can’t justify paying $650 for the engine quest drill fixture
Nov 04, 2017 3:51 PM
montrosepatriot
would like 2 manufacture one of these but for a Small Block Chevrolet (the Engine Quest drill fixture is $650 but this alternative comes first - need the materials used 4 the drill jig
- Keyway cutting on lathe by carl blum on 2024-10-16 12:35:21
- Instagram models - GIFs by InstagramBot on 2024-10-16 12:01:02
- Motorized easy access car seat - GIF by ToolTalkBot on 2024-10-16 10:27:01
- Shock testing computer monitors - GIF by Hoosiersmoker on 2024-10-16 09:59:55
- Team of people install huge window - GIF by Hoosiersmoker on 2024-10-16 09:56:11
- Concrete edging and tracking - GIF by ToolTalkBot on 2024-10-16 08:14:01
- Neat concrete block mortaring work - GIF by ToolTalkBot on 2024-10-16 06:07:01
- 250. Guide boards allow you to safely get closer to the blade by Make Things on 2024-10-16 02:28:52
- Robotic media blaster - GIF by IntheGroove on 2024-10-15 22:42:45
- Laser cleaning a fireplace surround - GIF by ToolTalkBot on 2024-10-15 20:27:01
DIY Fuel Pump Push Rod Fixture - comment on how to build a Fuel Pump Push Rod Fixture - 4 comments
warning says:
montrosepatriot says:
