Homemade Lathe Oil Drain Tools
The Hobby Machinist NZ on homemadetools.net
Homemade lathe oil drain tools constructed from a funnel, a wood block, and a PVC pipe. Used for different areas of the lathe.
- Neat concrete block mortaring work - GIF by ToolTalkBot on 2024-10-16 06:07:01
- 250. Guide boards allow you to safely get closer to the blade by Make Things on 2024-10-16 02:28:52
- Robotic media blaster - GIF by IntheGroove on 2024-10-15 22:42:45
- Laser cleaning a fireplace surround - GIF by ToolTalkBot on 2024-10-15 20:27:01
- Ox-driven chaff cutter - GIF by ToolTalkBot on 2024-10-15 19:13:01
- Power Steering Hose Fitting by gatz on 2024-10-15 17:19:43
- Bettie Page at Funland Amusement Park in 1954 - photo by Floradawg on 2024-10-15 16:49:27
- Wrench molding press - GIF by Floradawg on 2024-10-15 16:26:45
- Paint roller cleaner - GIF by Floradawg on 2024-10-15 16:24:49
- Wave soldering - GIF by ToolTalkBot on 2024-10-15 15:42:01
DIY Lathe Oil Drain Tools - comment on how to build a Lathe Oil Drain Tools - 0 comments
Be the first to comment on this DIY Lathe Oil Drain Tools, or add details on how to make a Lathe Oil Drain Tools! Click the "add comment" button above to comment.
