Homemade Mill Coolant Misting System
JimGlass on chaski.org
Homemade coolant system intended to spray a mist of WD-40 during aluminum milling operations. Utilizes a PVC pipe to hold the liquid WD-40. A pressure regulator and a pair of flow control valves handle the flow of air and coolant.
Apr 16, 2015 12:28 AM
DIYer
Cool setup. Seems like a waste to use WD-40, but if this is being used in a production capacity, then the customer will be paying for it.
- CNC lathe spindle shaft - video by Jon on 2024-10-16 13:53:17
- Roller stand from scissor jack - video by Jon on 2024-10-16 13:46:20
- Piston ring end gap grinder - video by Jon on 2024-10-16 13:44:49
- Powder coating oven - video by Jon on 2024-10-16 13:44:20
- Engine leveler - video by Jon on 2024-10-16 13:43:32
- Pressure washer from chainsaw - video by Jon on 2024-10-16 13:43:15
- C-clamp - video by Jon on 2024-10-16 13:41:30
- High-rise building excavator demolition - GIF by albertq on 2024-10-16 13:38:03
- UH-25B helicopter escape system - GIF by albertq on 2024-10-16 13:31:27
- Steam cleaning exterior wall - GIF by ToolTalkBot on 2024-10-16 12:56:02
DIY Mill Coolant Misting System - comment on how to build a Mill Coolant Misting System - 1 comments
DIYer says:
