Homemade Oil Cooler Pressure Tester
boyt911sc on forums.pelicanparts.com
Homemade pressure tester for an oil cooler. Constructed from a water pump T-fitting, a tire valve mounted via a water hose fitting, and a pressure gauge. The tester is attached to the oil cooler by means of a short hose and worm clamps.
Nov 21, 2013 4:10 PM
DIYer
A simple rig that should work with most oil coolers.
- CNC lathe spindle shaft - video by Jon on 2024-10-16 13:53:17
- Roller stand from scissor jack - video by Jon on 2024-10-16 13:46:20
- Piston ring end gap grinder - video by Jon on 2024-10-16 13:44:49
- Powder coating oven - video by Jon on 2024-10-16 13:44:20
- Engine leveler - video by Jon on 2024-10-16 13:43:32
- Pressure washer from chainsaw - video by Jon on 2024-10-16 13:43:15
- C-clamp - video by Jon on 2024-10-16 13:41:30
- High-rise building excavator demolition - GIF by albertq on 2024-10-16 13:38:03
- UH-25B helicopter escape system - GIF by albertq on 2024-10-16 13:31:27
- Steam cleaning exterior wall - GIF by ToolTalkBot on 2024-10-16 12:56:02
