Homemade Sportster Clutch Hub Removal Tool
arkyboy on xlforum.net
Homemade tool intended to facilitate the process of removing the clutch hub nut on 1970 and earlier Harley Sportsters. Fashioned from two surplus clutch plates bolted together, with nuts utilized as spacers between the plates. A flat bar attached to two bolts serves as the handle.
Post a comment
  1. Machining spiral spindles - GIF by ToolTalkBot on 2025-01-17 21:51:01
  2. Using a magnet to remove scrap from a railroad track - GIF by Elizabeth Greene on 2025-01-17 20:48:38
  3. Making a coin bracelet - GIF by ToolTalkBot on 2025-01-17 20:27:01
  4. Making an ice boat - GIF by that_other_guy on 2025-01-17 19:49:13
  5. Roots burst through PVC pipe - GIF by that_other_guy on 2025-01-17 19:36:11
  6. Revolving restaurant buffet in Taiwan - GIF by that_other_guy on 2025-01-17 19:33:28
  7. Tamp shoeing asphalt - GIF by that_other_guy on 2025-01-17 19:26:20
  8. An excavator held up by a crane - GIF by that_other_guy on 2025-01-17 19:24:36
  9. Puppet filming behind the scenes - GIF by that_other_guy on 2025-01-17 19:22:38
  10. Mining coal - GIF by that_other_guy on 2025-01-17 19:19:02
DIY Sportster Clutch Hub Removal Tool - comment on how to build a Sportster Clutch Hub Removal Tool - 0 comments
Be the first to comment on this DIY Sportster Clutch Hub Removal Tool, or add details on how to make a Sportster Clutch Hub Removal Tool! Click the "add comment" button above to comment.
