Homemade Worn Indicator Shaft Fix
mr_modify1 on homemadetools.net
Homemade worn indicator shaft fix constructed by reorienting the collar where the shaft slides through. Helps remove shaft play on an old dial indicator.
- CNC lathe spindle shaft - video by Jon on 2024-10-16 13:53:17
- Roller stand from scissor jack - video by Jon on 2024-10-16 13:46:20
- Piston ring end gap grinder - video by Jon on 2024-10-16 13:44:49
- Powder coating oven - video by Jon on 2024-10-16 13:44:20
- Engine leveler - video by Jon on 2024-10-16 13:43:32
- Pressure washer from chainsaw - video by Jon on 2024-10-16 13:43:15
- C-clamp - video by Jon on 2024-10-16 13:41:30
- High-rise building excavator demolition - GIF by albertq on 2024-10-16 13:38:03
- UH-25B helicopter escape system - GIF by albertq on 2024-10-16 13:31:27
- Steam cleaning exterior wall - GIF by ToolTalkBot on 2024-10-16 12:56:02
DIY Worn Indicator Shaft Fix - comment on how to build a Worn Indicator Shaft Fix - 0 comments
Be the first to comment on this DIY Worn Indicator Shaft Fix, or add details on how to make a Worn Indicator Shaft Fix! Click the "add comment" button above to comment.
