Homemade LB7 Fuel System Repair Verifying Tool
bullfrogjohnson on duramaxdiesels.com
Homemade LB7 fuel system repair verifying tool intended as a means of checking the return line system for leaks prior to engine reassembly. Consists of a Mityvac handheld vacuum/pressure gauge and tubing, the end of a surplus fuel return line, a fuel return line bolt, and a banjo washer. Tool is installed on the cylinder head's fuel return outlet to apply vacuum to the system.
- CNC lathe spindle shaft - video by Jon on 2024-10-16 13:53:17
- Roller stand from scissor jack - video by Jon on 2024-10-16 13:46:20
- Piston ring end gap grinder - video by Jon on 2024-10-16 13:44:49
- Powder coating oven - video by Jon on 2024-10-16 13:44:20
- Engine leveler - video by Jon on 2024-10-16 13:43:32
- Pressure washer from chainsaw - video by Jon on 2024-10-16 13:43:15
- C-clamp - video by Jon on 2024-10-16 13:41:30
- High-rise building excavator demolition - GIF by albertq on 2024-10-16 13:38:03
- UH-25B helicopter escape system - GIF by albertq on 2024-10-16 13:31:27
- Steam cleaning exterior wall - GIF by ToolTalkBot on 2024-10-16 12:56:02
DIY LB7 Fuel System Repair Verifying Tool - comment on how to build a LB7 Fuel System Repair Verifying Tool - 0 comments
Be the first to comment on this DIY LB7 Fuel System Repair Verifying Tool, or add details on how to make a LB7 Fuel System Repair Verifying Tool! Click the "add comment" button above to comment.
